Non-default administrator account Extension Attribute
  • February 8, 2013
  • 9 replies
  • 28 views
I find myself taking a lot from jamfnation and not giving much back in return, so here is my simple little extension attribute for showing all non-default administrator accounts from Macs in your estate. You will need to change the underscored section for your environment. I use this with Smart Groups to generate emails after a recon has detected this attribute has a value.
Date Type: String
Input Type: Populated by Script
Script Contents:
groupmember=`dscl /Local/Default read /Groups/admin GroupMembership | tr ' ' '
' | grep -Ev 'root|change_for_your_default_admins_separated_by_pipes|GroupMembership:|admin' | tr '
echo "<result>$groupmember</result>"
It basically reads the membership of the local administrator group and removes values (your default admins + additional info) from the output, leaving you non-default members of the local admin group.
If you work in an environment that has compliancy audits then this is really useful for checking all local administrators are justified.
Forum|alt.badge.img+23
  • February 8, 2013
Brilliant! Been trying to develop something like this for some time now!
  • February 8, 2013
Curious; doesn't seem to work as expected for me, unless I'm not understanding the approach. I've got two local admins on this box and neither is being returned (I didn't add them to the exclusion list).
I've taken a different approach to this:
Note: Perl!
#!/usr/bin/perl -w
$adminUsers = `dscl . -read /Groups/admin GroupMembership | sed 's/.*abuiltinadmin//;s/.*someotheradmin//;s/^[ 	]*//;s/ /, /g'`;
chomp $adminUsers;
if (length $adminUsers==0){
   print "<result>No admins</result>";
   exit 0;
} else {
   $resultMessage = join('', '<result>', $adminUsers, '</result>');
   print $resultMessage;
   exit 0;
Note that it's also a comma-separated list, but you could modify that.
  • February 8, 2013
AH, I found your problem - any local administrative account with "admin" in the name will NOT be returned because you grep out 'admin'. Whoops!
  • February 8, 2013
Another route you could go would be to limit to accounts with UID over 500. In our case, our casper admin account is hidden (sub 500) so the ones we care about being admin are over 500.
  • February 8, 2013
That was the issue I had Jared. Problem with that is all our AD users have UID's over 1000 regardless.
Forum|alt.badge.img+31
  • February 8, 2013
This is exactly what I did when I was a System Administrator using Casper at my last job. All local admin accounts were under UID 500. I had three of them. One was for Casper itself, which was deployed via quickadd, or at imaging time and was never used by anyone. The second one was for internal IT use, also hidden, and UID under 500. The last one was also under UID 500 and hidden but was used for any non IT worker that needed Admin rights. I used separate accounts because I wanted the ability to nuke them remotely if a password leaked, and not have it affect IT or Casper.
I have posted this script a ton of times on the mailing list back in the day and it is probably on the forums here, but this is how I handled admin detection for AD/OD accounts:
# check for admin accounts
userList=$(dscl . list /Users UniqueID | awk '$2 > 1000 { print $1 }')
for u in ${userList} ; do
if [[ `dscl . read /Users/${u} GroupMembership | grep -c "admin"` == 1 ]]
then echo "<result>${u} is admin</result>"
else echo "no admin here"
done
This was written I think for 10.6.x so please test this out. Hope this helps some of you.
-Tom
  • February 8, 2013
Sorry in my environment we don't have any default admins actually called admin but I guess you could add additional extended regex to differentiate.
Seeing some nice responses so that's awesome, mine was a very simple way that worked very well for me. :-)
Corrected original extension attribute:
' | grep -Ev 'root|change_for_your_default_admins_separated_by_pipes|GroupMembership:' | tr '
Removed the unneeded "admin" from the grep -Ev, it's best to add your admin's complete shortname for the most accurate results.
  • September 26, 2018
As this was a topic for us again - the following one works on High Sierra and Mojave:
(Note: add your default admins in the grep command)
#reporting of (additional) local admins
#v1.0, Andreas Rumpl, 2018-09-26
#search for local admin users and exclude the predefined Service users
#if there is an additional admin existing, report it
if [[ "$groupmember" != "" ]]; then
    echo "<result>no local admin rights</result>"
mani2care
  • May 27, 2020
@AndreasRumpl @vadanx
I was tried in locally running the script but the Extension Attribute not working getting blank result only
