If anyone is having an issue similar to...
https://www.jamf.com/jamf-nation/discussions/28736/mdm-profile-unverified-signing-certificate-expired
The issue I had was the enrollment profile was verified, but the other profiles (Restrictions, Security, etc) were unverified after one year passed.
I spent a couple hours searching here and elsewhere and found nothing, but the solution was so simple...
- Log in to Jamf Now
- Go to the blueprint containing the unverified profiles
- Make a minor change to that section
- Undo that change
- Save
That's it! In moments the new profile will be pushed to the device and the red "unverified" will change to green "verified".
I hope that helps someone! (Now, let's hope people having this issue can actually find this post!)
