Installing 8x8 Work App via Jamf
  • June 30, 2021
  • 6 replies
  • 27 views
Does anyone know if the 8x8 Work app can be deployed via Jamf? I tried converting the dmg to a pkg in composer, but that didn't seem to work. I'm also open to using a script to install it. Any thoughts are appreciated. Thank you!
junjishimazaki
@sfaeder , I use a script to deploy most of my applications fro Jamf
Here is my script for 8x8
!/bin/sh
Universal App Installer Script
DESCRIPTION
Automatically download and install nearly any app from a direct download link
App can be packaged as .dmg, .pkg, or .zip, and have either the .app or a .pkg inside
ADD THE DIRECT DOWNLOAD LINK FOR YOUR APP HERE:
Example: DownloadURL="https://dl.google.com/chrome/mac/stable/googlechrome.dmg"
DownloadURL="https://vod-updates.8x8.com/ga/work-dmg-v7.7.4-1.dmg"
LEAVE THIS CODE ALONE:
Create directory /tmp/jamf, continue if directory already exists
mkdir /tmp/jamf || :
Change directory to /tmp/jamf
cd /tmp/jamf
Download installer container into /tmp/jamf
-O downloads file without changing its name
curl $DownloadURL -O -L
If container is a .dmg:
Mount installer container
-nobrowse to hide the mounted .dmg
-noverify to skip .dmg verification
-mountpoint to specify mount point
yes | hdiutil attach /tmp/jamf/*.dmg -nobrowse -noverify -mountpoint /tmp/jamf/mount ||
Else if container is a .pkg
Run installer package with the boot drive as the destination
installer -pkg /tmp/jamf/*.pkg -target / ||
Else if container is anything else, presumably a zip file:
Unzip installer container and place contents into /tmp/jamf/mount, continue on error
unzip /tmp/jamf/* -d /tmp/jamf/mount || :
If contents is installer .pkg:
installer -pkg /tmp/jamf/mount/*.pkg -target / ||
Else if contents is .app:
Copy the .app file from the installer container to /Applications
Preserve all file attributes and ACLs
cp -pPR /tmp/jamf/mount/*.app /Applications || :
Unmount the secondary installation folder, continue on error
hdiutil detach /tmp/jamf/mount || :
Delete the main installation folder
rm -r /tmp/jamf
junjishimazaki
This script will work for most or all dmg file types. I just point the installer to the downloader link. The script does the rest
  • June 30, 2021
Dude you are awesome! This worked!! Thank you so much!!!!
junjishimazaki
You're welcome. This is basically a universal dmg installer. As long as you have the dmg installer link you can use this script.
  • May 30, 2023
Will this script work for both versions of the installer now out for macs? M1 and Intel platforms.
junjishimazaki
I posted this script 2 years ago, so things get updated....with that being said. If you went to the 8x8 download site there are 2 versions (one for intel and one for apple silicon).  So, just update the script and create a conditional statement to check if the Mac is intel or arm processor. If it's an Intel processor, assign the download variable the Intel installer link and if it's an Apple Silicon then assign the download variable the Apple Silicon installer link.
