Will the primary users of the Mac be logged into those devices when the script runs? If so, the following code will get their shortname/username, which you can then place back into the command, I assume. I don't have experience with this Canon printing service myself, so I'm just guessing on the last part.
logged_in_user=$(/bin/echo "show State:/Users/ConsoleUser" | /usr/sbin/scutil | /usr/bin/awk '/Name :/&&!/loginwindow/{print $3}')
So, depending on how you are adding those print URLs during the deployment, if it's being scripted, you would just place that logged_in_user
variable into the mix, like so
lpd://${logged_in_user}@123.45.678/PrintAnywhere
Again, I can't test the above, so I have no idea for sure if that would work, but give it a try and see.
Yes they will be. Thank you. I'll get to testing with some scripts built around this
I have been configuring this before and what @mm2270 is suggesting is the way to go.
Just note that your printing system probably read usernames from the AD (if you don't use a local DB), and that means that the local username needs to match the AD username.
So depending on your environment I would say go with one of the following:
- Read local username
- Read AD username from a source that you have available (EC, NoMAD, JC)
- Prompt the user to enter their AD username (I used this for BYOD scenarios)
This is a project that may be on my plate in December. We will pull creds from EC, while prepping for Connect as you are. Glad you folks are already discussing it!
We are a Canon Uniflow shop and our script checks that the printer drivers are installed first (you should not use generic PostScript, but rather Canon's UFR II CUPS drivers). Then it uses a similar technique as @mm2270 to add the printer...
/usr/sbin/lpadmin -p "$lpqueue" -E -v lpd://${username}@${printServer} -m "$printerModel" -o printer-is-shared=false
lpqueue = the printer queue path, like "SecurePrint-Mac"
username = self-explanatory, pulled from local
printServer = the FQDN of the Uniflow print server
printerModel = the path to the print drivers
In this example, documents would be sent for 'bradtchapman' to a Uniflow secure print queue, using the print driver for the Canon ImageRunner Advance C5550, and the 'share printer' option is turned off in the Printers preference pane (reduces Bonjour traffic, prevents excessive duplicates appearing on other Macs)
lpd://bradtchapman@uniflow-la-001.pretendco.com -m "/Library/Printers/PPDs/Contents/Resources/CNMCIRAC5550S2.ppd.gz" -o printer-is-shared false"
Alternatively, if the computer is assigned in Jamf to a user's short name, you can pull the 'username' from the Jamf computer record via API in your script.
Apologies for bringing up an old post, but I am trying to setup Canon Secure Print as well.
If the login username differs from the user logon on AD, is it pretty much not possible to setup?
Thank you,
Thank you,
Hi @box ,
prior to our implementation of Automated Device Enrollment, wherein we require authentication—this sets the user affinity for the Mac in Jamf and creates a matching local account / home folder—sometimes local user names would not match the active directory user name of the assignee. In this scenario, we have an in-house script in Self Service that prompts the user for their Active Directory username. Granted, there's no way to validate it ... but if they aren't careful and end up sending print jobs to johndoe instead of johndoe1, they simply won't be able to retrieve them. All they need to do is run the script again and set the secure printer using the correct username.
We built ours around Pashua (now defunct) but you can absolutely use SwiftDialog.
Hi @box ,
Thank you for the reply.
The account I am using matches the AD naming conv.
I installed all drivers and yet unable to add Secure Print on MacOS.
Is there something on the UniFlow side that needs to be done?
Hello there. In order to get this to work, you will need to enable the LPD service if you are using an on-premise Printserver. Wasn't sure if you had mentioned that.
can i ask a bit more about this. We are just setting up uniflow cloud hosted. We created the installer per the nice instructions by another jamf user repackaging the Smart Client for uniflow to actually install. The regular package installs the "secure print" driver as "UniFlow Online 2020" with no default options listed. Are you saying to edit the driver it uses from the UNiflow one to the canon specific driver? This "driver" is supposed to be "universal" (notice all the quotes) but we are seeing it cannot default things to say black and white only or 2 sided.
If you're looking at Uniflow drivers with a specific year next to them, you're looking at either the server-side "universal" driver package for Windows, or the Uniflow application itself. The universal drivers are only for Windows clients. Printers shared from a server can be auto-configured for Windows clients if the shared printer has drivers selected.
For Mac clients, you will need the PPD or UFRII drivers for Mac. Choose a printer model that is most common in your fleet of multifunction copier/printers. For instance, the imageRUNNER C5550. You'd download those drivers, keep them in the .pkg format as delivered, and deploy them en masse to your Macs ahead of time.
When you're ready to configure a Uniflow Secure Printer queue, use the lpadmin command above. Wrap it in a nice script with a GUI if you're feeling up to it.
