Hey Everyone, I am trying to get Macbooks fresh off of a prestage enrollment rename to the serial number using $SERIALNUMBER in the clientid of the directory payload. It doesn't seem to be working. Do I have the variable wrong? Are there other parts of a configuration profile that could block the rename? Should I break out the AD Bind payload from other prestage config profile items? Any guidance or even places to look to troubleshoot would be appreciated. Thanks
ClientID Variables not setting on ad bind
