Remove skype integration with outlook Mac
  • July 14, 2021
  • 11 replies
  • 66 views
Can anyone tell how to remove skype integration with outlook Mac
  • July 14, 2021
You can use the terminal command..
defaults write com.microsoft.Outlook DisableSkypeMeeting -bool TRUE
.. or create a configuration profile and addressing the com.microsoft.outlook domain with the boolean option set to TRUE.
  • July 14, 2021
I ran this command in terminal but still Skype Meeting button available in outlook.
  • July 14, 2021
Did you run the command as root or admin with sudo?
  • July 14, 2021
I only paste below command in terminal
  • July 14, 2021
try it as root user with the following steps:
  • close Outlook
  • run the command (as root user)
sudo defaults write com.microsoft.Outlook DisableSkypeMeeting -bool TRUE
  • open Outlook
  • July 14, 2021
I believe this can be accomplished with a Configuration Profile.
Application & Customer Settings > External Applications > com.microsoft.Outlook > Disable Skype for Business meeting support > True.
This uses the same DisableSkypeMeeting key.
  • July 15, 2021
What is the location of this Configuration Profile in Mac?
  • July 15, 2021
  • close Outlook
  • open Outlook
@frootion wrote: prepaidcardstatus
  • close Outlook
  • open Outlook
Great article. Very well explained. Thanks for the share.
  • July 15, 2021
I don't remember when it was added but maybe 10.25.2 of JAMF.
Computers > Configuration Profile > New > Application and Custom Setttings > External Applications > Add > Choose a source > Jamf Repository > com.microsoft.Outlook
Preference Domain Properties > Disable Skype for Business meeting support
  • July 15, 2021
@ravi_k_verma  - have you tried to https://office-reset.com/ app? It has worked wonders for me.
It was created by @pbowden
  • July 16, 2021
Yes tried but it's removing Skype for business completely and I want to remove Skype meeting button from outlook only
Disclaimer: This email and any attachments are sent in strictest confidence for the sole use of the addressee and may contain legally privileged, confidential, and proprietary data. If you are not the intended recipient, please advise the sender by replying promptly to this email and then delete and destroy this email and any attachments without any further use, copying or forwarding.
