Self Service v10.30.3 macOS not connecting
  • July 15, 2021
  • 11 replies
  • 79 views
I upgraded to 10.30.3 yesterday and noticed now that my macOS Self Service is not connecting, iOS Self Service is still operational.  There is no crash like I've read others experiencing.  I am working with support on this, just curious if anyone else has ran into this and possibly found a fix?
TIA,
Chuck
scottb
  • July 15, 2021
What happens if you type this on the Mac:
jamf checkJSSConnection
  • July 15, 2021
Yep one of the first command I ran, "The JSS is Available"  Push Cert has a valid date, and commands from the JSS to a macOS device are also working.
scottb
  • July 15, 2021
So, what if you delete Self Service.app and then run a recon - it should give you a new SS app.  See if that helps, and possibly, look to Keaychain Access.app to remove the SS keys before installing SS again...
com.jamfsoftware.SelfService.privatekey
com.jamfsoftware.SelfService.publickey
  • July 15, 2021
I've tried that as well.  No luck.
scottb
  • July 15, 2021
Have you tried unenrolling and re-enrolling?
Double-checked that the MDM profile is still approved?
  • July 15, 2021
I hadn't tried a re-enroll until your suggestion.  Thankfully that didn't work.  I couldn't imagine having to re-enroll 5000 computers just to get Self Service to work.
MDM Profile looks good.
scottb
  • July 15, 2021
Take a look at this thread - so many possibilities that I think maybe something in there might help.
Also, if you have other items involved like Intune, Jamf Connect, etc. there may be more complex issues at hand...
Check this link below:
Self Service Issues
  • July 16, 2021
I was running into this issue this morning. I was attempting to install some VPP apps from Self Service and it was failing immediately with the error reported by OP "Couldn't connect to the Jamf Pro Server. Try Connecting Again". I checked to make sure I could retrieve policies and ran recon all fine, so I uninstalled and reinstalled Self Service and seemed to clear up the problem. If the issue comes back I'll update.
  • August 2, 2021
I am also having this issue, started when I updated as well. I have tried all of the solutions suggested below. Deleted the app. Reenrolled. Removed the keychain items and no solution.
  • August 3, 2021
I might have a new cause and fix for you.  Support found my problem.  If you currently have any macOS Configuration Profiles that have "Make Available in Self-Service" it is causing Self Service to have this problem.
Fix and I quote Austin from my support ticket  "You can either set this to deploy automatically or disable/delete it.  If this fixes Self Service, we are running into PI-009440, a known issue with this version of Jamf Pro that is caused by adding a malformed Configuration Profile to Self Service."
I hope this helps!
Chuck
jamesandre
  • November 17, 2021
I had two com.jamfsoftware.SelfService.privatekey entries in the login Keychain.
Deleting both the private keys, public key and Self Service, then waiting for Self Service to get re-installed sorted it for me.
