So we're currently experiencing an issue where some computer records in Jamf Pro do not contain an up to date list of the installed configuration profiles. Running jamf recon does not appear to correct this. Is there a way to either update or clear the list of installed configuration profiles in a Jamf Pro computer record?
Update computer record with list of installed configuration profiles?
