Recon cannot ssh into os x machines
  • February 19, 2016
  • 5 views
Whether I am trying to enroll the machine that i have recon installed on, or workstations on the LAN, recon always says that ssh fails to make the socket connection even though I can manually verify that ssh is working both locally and on remote hosts.
Thanks in advance!
1 reply
bentoms
Forum|alt.badge.img+35
  • February 20, 2016
@karnold I've not tried SSHing into a Mac I'm on, but that would be something to try to see if that errors.
Else, it you're trying to submit recon. Why not run the below in terminal?
sudo jamf recon
