Jamf Flushing Policy Logs for Multiple Computers
  • July 28, 2021
  • 4 replies
  • 39 views
Hi
Am new to Jamf and still working things out.
We have 550 Mac's and when we wipe and re-install them is there a way to flush policy logs for them all.
Don't really want to flush them one by one.
Thanks
Forum|alt.badge.img+20
  • July 28, 2021
Go in to your System Settings -> Global Management -> Re-enrollment and enable `Clear policy logs on computers`. Now, when you re-enroll a computer, all existing policy logs will be flushed and all policies will run again.
junjishimazaki
I think the best approach to this, is when you and your IT team wipe/re-install the OS, delete the Mac record prior to the wiping. When you re-enroll again, it gets a clean slate record.
  • July 28, 2021
Thanks for the replies, that's great
  • July 30, 2021
We do the same as @junjishimazaki
it will also make sure that Configuration Profiles are not linked
