Users who stay on the login screen for a while, gets a message asking "if they forgotten their pw"
  • July 30, 2021
  • 8 replies
  • 24 views
Hello,
My users when they turn on their machines, and stay on the login page, get a prompt asking if they forgot their passwords. and to restart the machine it will automatically do recovery mode for them.
Well users being users dont read, and restart their machine for some reasons, and it brings them to recovery mode, where they meet a lockpad.
Is there a way to turn off that prompt and action?
Thank you!
Hammy Choi
Best answer by mm2270
I wish there was. I've had a few Mac users get to the firmware lock screen inadvertently because of those same messages. It's annoying, but Apple provides no way to disable those messages that I've been able to find. Only thing you can do is user education and hope people remember not to do that.
We're instructing users that if they have forgotten their account password or it's not working to unlock the Mac to contact support and we can provide them with their individual FileVault Recovery key. From there they can get in and if needed, reset their password locally.
DBrowning
  • July 30, 2021
So the login screen you are speaking of here is the FileVault Login Screen.  This is a default of the OS when FileVault is enabled.  There is no way to turn it off that I'm aware of other then disabling FileVault.
  • July 30, 2021
Hey DBrowning,
Thank you for the reply. What do you think about the Prompt asking if they forgot their passwords? Is there a way to disable that? The one that forces it to recovery mode if you restart.
Hammy Choi
DBrowning
  • July 30, 2021
Unfortunately not that I'm aware of.
  • July 30, 2021
  • July 30, 2021
Hey mm270,
Thank you for your reply. That is exactly the situation I been running into. Lets hope one day that will change and we can disable that.
Hammy Choi
Users who stay on the login screen for a while, gets a message asking "if they forgotten their pw". Go to solution. sonny_trinh. New Contributor II. Options.
My Balance Now
  • December 3, 2021
The authority management team members should rethink about the forgotten pw issue since many customers need to discover it. Thanks for letting us know about the procedure to get back the pw for accessing into the services.
chatrandom
  • February 14, 2022
It's so typical for users not to read any message and fail to ordinary tasks like this. In my opinion either the text should be more visible (use bigger font), or extra images need to use.  In my project chatroulette we faced almost identical issue and it was solved by adding extra screen where users must manually confirm their decision (they need to write a text). Obviously, it's not a good decision for your issue but maybe it will drive you to look for new ideas.
