Jamf API xmllint --xpath Question
  • August 3, 2021
  • 57 views
Searched Jamf Nation but couldn't find anything close enough to my use case.
I'm querying the Jamf API for computer IDs by way of usernames:
jamfUserURL="https://[company].jamfcloud.com/JSSResource/users/name/$username" computerID="$(curl -X GET -s -k -u "$jamfUser":"$jamfPass" "$jamfUserURL" | xmllint --xpath '/user/links/computers/computer/id/text()' - )" echo $computerID
 This works great except for end users who have more than one computer in the environment. Then I get a result with all IDs combined into one return. Would it make sense to stick this in a for loop to iterate through the multiple IDs? If so, can someone please assist?
Best answer by druocco
Thanks @boberito! I'll give this a run and see what happens.
I actually stumbled on another way as well:
computerID="$(curl -X GET -s -k -u "$jamfUser":"$jamfPass" "$jamfUserURL" | xmllint --xpath '/user/links/computers/computer/id' - | awk -F'>|<' '/id/{print $3}')"
The 'awk' did it.
boberito
Forum|alt.badge.img+22
  • August 3, 2021
You have to do something funky
Due to the version of xmllint included with macOS it doesn't have the argument to split things off to different lines easily. I ran into this recently and came up with this solution. You can just change some pieces to meet your need
curl -s -u "${jamfaccount}:${jamfpass}" -X GET "${jamfurl}JSSResource/advancedcomputersearches/id/${acsID}" -H 'Accept: text/xml' > curloutput computers="$(xmllint --shell <<< "cat /advanced_computer_search/computers/computer/id/text()" curloutput)" computerIDs="$(echo $computers | awk -F" ------- " '{$1=""; print $0}')" for computerID in $computerIDs; do re='^[0-9]+$' if ! [[ $computerID =~ $re ]] ; then continue fi echo $computerID done
  • August 3, 2021
The 'awk' did it.
  • March 17, 2023
I get
-:1: parser error : Start tag expected, '<' not found
?PNG
