Best way to remotely wipe a machine and reinstall MacOS
  • August 19, 2021
  • 120 views
I'm trying to find the best way to remotely wipe out a machine and do a full reinstall of the MacOS.
I've taking a look at this article (https://www.jamf.com/blog/reinstall-a-clean-macos-with-one-button/) but haven't been able to fully get it to work and I'm looking for other solutions in the meantime.
After a computer is returned by a user I'll usually wipe it out and reinstall the O/S and I'm hoping Jamf can help automate this to a few clicks. Most of the time the computer is in another location so I can't just do it manually.
Thanks for any suggestions.
  • August 19, 2021
Problem sort of resolved. I recreated the policies based on the above linked article and it now seems to have worked.
  • August 19, 2021
latley I have been crushing on this by Graham Pugh and Datamind. https://github.com/Datamind-dot-no/auto-erase-install
