I'm going to attach some scripts that i mentioned in the meeting
Bind to Active Directory Script
## Use your FQDN domain name between the quotes
**dsconfigad -add "insert AD server here"**
## A username with binding authority
**-username "insert AD binding username here"**
## Password for the above user
**-password "insert password here"**
## Enter the computer name, or direct the script to pull the computer name with
## something like "scutil --get ComputerName"
**-computer "$1"**
## Set to disable if you don't want mobile accounts
**-mobile enable**
## Goes in hand with the above setting, warns on mobile account creation, or not
**-mobileconfirm disable**
## Use disable if you don't want a locally cached home directory
**-localhome enable**
## Set to enable or disable based on whether the HOME should mount based on UNC path
**-useuncpath disable**
## Leave this as is unless you have a good reason to change the default user shell
**-shell /bin/bash**
## Set your OU to join the Mac to here
**-ou "enter your OU here"**
## Add any AD groups here that you want to allow local admin access on the Macs
## while in range of your DC
#**-groups "ORGmac admins"**
echo "result of last command:" $? >> /var/log/jamf.log
Unbind From Active Directory Script
# Copyright (c) 2010, JAMF Software, LLC. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of the JAMF Software, LLC nor the
# names of its contributors may be used to endorse or promote products
# derived from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
# This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
# information or support for the Resource Kit, please utilize the following resources:
# http://list.jamfsoftware.com/mailman/listinfo/resourcekit
# http://www.jamfsoftware.com/support/resource-kit
# Please reference our SLA for information regarding support of this application:
# http://www.jamfsoftware.com/support/resource-kit-sla
# ABOUT THIS PROGRAM
# NAME
# unbindAD.sh -- Unbind from Active Directory.
# SYNOPSIS
# sudo unbindAD.sh
# sudo unbindAD.sh <mountPoint> <computerName> <currentUsername> <username> <password>
# If the $username and $password parameters are specified (parameters 4 and 5), these will be
# used to unbind the machine from Active Directory. The username/password that should be used in
# this script should be an Active Directory user that has permissions to remove/unbind a machine
# from Active Directory.
# If no parameters are specified for parameter 4 and 5, the hardcoded value in the script will be
# used.
# DESCRIPTION
# This script will unbind a client machine from an Active Directory domain.
# The <username> and <password> values can be used with a hardcoded value in the script, or read
# in as a parameter. Since the Casper Suite defines the first three parameters as (1) Mount
# Point, (2) Computer Name and (3) username, we are using the fourth parameter ($4) as the
# passable parameter.
# HISTORY
# Version: 1.0
# - Created by Nick Amundsen on August 7th, 2008
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUES ARE SET HERE
username="Put your AD Authenticating Username here"
password="Put your password here"
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 4 AND, IF SO, ASSIGN TO "username"
if [ "$4" != "" ] && [ "$username" == "" ]; then
username=$4
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 5 AND, IF SO, ASSIGN TO "password"
if [ "$5" != "" ] && [ "$password" == "" ]; then
password=$5
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$username" == "" ]; then
echo "Error: No username is specified. Please specify a network username."
exit 1
if [ "$password" == "" ]; then
echo "Error: No password is specified. Please specify a network password."
exit 1
echo "Unbinding the computer from Active Directory..."
/usr/sbin/dsconfigad -r -u "$username" -p "$password" -force
echo "Restarting Directory Services..."
/usr/bin/killall DirectoryService
sleep 15
Script we use to Bless netboot and boot to our netboot server when imaging. Use this script at your own risk, make sure to test it first because it could require quite an amount of tweaking
# Create time date stamped log
#Created and Updated Partially By Justin Reeves 2015
logFile="/private/var/log/OurCompany.log"
log () {
/bin/echo $1
/bin/echo $(date "+%Y-%m-%d %H:%M:%S: ") $1 >> $logFile
log "-----"
log "Begin script 100_resetNetworkLocationAndPorts.sh"
log "Adjust Network Locations to correctly add network ports"
sleep 5
# Create a temporarily Network location and recreate the Automatic location.
networksetup -createlocation TempLoc populate
sleep 5
networksetup -switchtolocation TempLoc
sleep 2
networksetup -deletelocation Automatic
sleep 2
networksetup -createlocation Automatic populate
sleep 5
networksetup -switchtolocation Automatic
sleep 5
networksetup -deletelocation TempLoc
log “Network Location Setup Completed.”
#Restart to netboot macbook air
port=$(networksetup -listallhardwareports | awk -F: '/Thunderbolt Ethernet/{getline;print $2}' | tr -d " ")
##The line below will print the network interface
echo $port
sudo bless --netboot --verbose --nextonly --server bsdp://"$port"@"your netboot servers ip address here without quotes"
I did not write all of these but i can confirm that they all work in my environment
