Apps not updating automatically
  • September 1, 2021
  • 5 replies
  • 32 views
Good morning,
I have all of our apps that are pushed down to the devices set to Automatically force updates. Updates are not happening. Is there a setting that I may be missing? I have spoken with a few device users and the devices are not being turned over night so the updates should be going through. Below is a screenshot of my setup for the app.
Thank you in advance for any advice.
Rachel
ljcacioppo
  • September 1, 2021
Are the devices in single app mode by chance? I don't think updates can happen if they're in single app mode
  • September 2, 2021
What jamf version are you running? Ive seen similar threads to this last year - Thought that maybe it was fixed already.
  • September 2, 2021
No we are not using single App mode.
  • September 2, 2021
We are on version 10.31.1-t1628520988. i have tried a force update and that is not working either.
  • September 16, 2021
I'm having the same problem here. Jamf Hosted Jamf Pro, version 10.31.1-t1628520988
Existing apps aren't updating automatically, but if I add a copy of the app as a new app it comes in with the new version number.
