Downloads folder in Jamf Configuration Profile for Dock
  • September 20, 2021
  • 37 views
WilsonFredonia
So I'm trying to play in the sandbox that Apple and Jamf seem to want us to be in and I am pushing out as much as I can through configuration profiles for the user experience in our labs.
I have unique docks built out for each of the different labs with a combination of the Dock portion of the config profile and an Application and Custom Settings JSON template that I found a ways back (Looks like it is this one. ). Everything seems to be working quite well and gives me a lot of flexibility across the spaces until I hit a coordinator who wants the user's Downloads folder available in the Stacks portion of the Dock. I have tried populating through the Custom Settings and through the Dock portion of the config profile with ~/Downloads and had no luck.
Anyone have any thoughts on how to point to a user's home directory that do not involve uploading an entire profile outside of Profile Creator or dockutil (tried both in the past)?
  • September 21, 2021
Dealing with this right now. It appears dock folders may be an issue if you're binding and the users don't have a mobile account i.e. network users. The dock payload won't be able to map the folder reliably if it's not a mobile account.
Other things to check are to use full paths with variables i.e. /Users/$4/Downloads or /Users/%USER/Downloads.
  • August 28, 2024
localhost/Users/$USER/Downloads
This worked for me
-SK
