Cannot Reach Jamf Pro Server
  • September 28, 2021
  • 14 replies
  • 82 views
Have apple school manager setup, and trying to deploy iMovie to a test MacOS.  Using Self Service and when the user clicks install it spins then comes back with an error saying "Cannot Reach Jamf Pro Server".  We are cloud hosted, I have tried the machine off the district internet incase a Firewall issue was causing it.  No luck,
I am able to deploy a custom package of Chrome from the Jamf Cloud distribution point.  I also have tried xcode also another free app and it still gives me the error of "Cannot Reach Jamf Pro Server"
Mac Store Apps do not install
Best answer by damienbarrett
so even though its free I have to buy it through the VPP store first?  Thats probably where I am making the first mistake.
You have to "buy" it (even if it's free) from the Apps and Books section in ASM so that it can synchronize licenses (even free licenses) with Jamf. And then you can use Jamf to assign licenses to machines. Yeah, it's a bit of a weird concept, but it works and once you've done it a few times, it'll feel more natural. Also, don't forget to check that "Assign Content" box.
garybidwell
  • September 29, 2021
Get Push Diagnostics installed on the Mac
https://apps.apple.com/us/app/push-diagnostics/id689859502?mt=12
This will save a whole heap of troubleshooting with what the device can or cannot communicate with Apple wise.
At least then you can see if APNs is being blocked
As for checking Jamf, run this command from the terminal
jamf checkJSSConnection -verbose
Are you using mobile accounts of any kind?
Both Pass, still not working.  Thanks for the idea.
No
Try issuing jamf checkJSSconnection in terminal and see what it returns.
damienbarrett
Forum|alt.badge.img+19
You're "purchasing" licenses for these free Apps in Apple School Manager, yes? And they equivalent number is showing up in the Mac Apps section of Jamf Pro? If so, great. Means the communication/sync and trust relationship between ASM, Jamf Pro, and App Store is working.
One thing that I se often, and have been caught myself several times, is that you have to remember to check the "Assign Content Purchased in Volume" checkbox under the "Managed Distribution" section for each App record in Jamf Pro. Even if you are distributing via Self Service (instead of automatically installing/deploying).
damienbarrett
That seams to have fixed part of the issue, but does the user have to sign into Apple to download it?  I thought with VPP they would not.
damienbarrett
Not if the license for an App is machine-assigned (that checkbox I keep pointing you to). No Apple ID or login to the App Store should be needed (for those Apps).
Yeah looks to have worked, thank you so much for your help.
damienbarrett
No problem. Happy to help.
  • December 16, 2022
I am still having an issue after trying all of these steps. It is still telling me "Cannot reach a Jamf MDM server" in Self Service.
  • February 4, 2023
Did you ever get that issue resolved.  I'm having the same thing
