Setting a desktop background image so it "Fits the Screen" on Mac computers?
  • October 6, 2021
  • 44 views
HI. I know how to push an image to my machines and how to set and lock the image as the background. What I'm having trouble with is setting the desktop settings so that the image is displayed as "Fit to Screen" instead of defaulting it seems to "Fill Screen".  The later doesn't display the entire image (which is basically a list of rules for my students to always see).  This is on Macbook Air laptops.
Is there any way to force how a background image is displayed once it's pushed and set? Via script, within Jamf itself, etc?
  • October 7, 2021
You can achieve that with the desktoppr tool: https://github.com/scriptingosx/desktoppr
desktoppr scale fit
  • October 15, 2021
desktoppr scale fit
Thanks! I'll give that a try and see how it works.
