Hey Everyone,
Has anyone had success netbooting the latest Apple Hardware (2012 Retina MBP and 2012 MBAs)?
I have tried just about every way I can possibly think of. Even attempting to use a combination of the full Bless and NVRAM commands directly calling out the network interface en1 instead of en0. The system only tries for a couple seconds and then goes to the local HD. If the system is on the same subnet it works by just choosing the drive in Startup Disk or holding down N during boot or holding down option and choosing the netboot server.
This is on a system that is fully up to date on firmware and OS (10.8.2 and 10.8.3 beta). This is on a Netboot server that is also fully up to date and on Apple hardware.
Any thoughts or ideas would be much appreciated.
Sample of the commands I have tried:
bless --netboot --server bsdp://en1@10.36.12.41
bless --netboot --server bsdp://en1@10.36.12.41 --booter tftp://10.36.12.41/NetBoot/NetBootSP0/CasperNetboot.nbi/i386/booter --kernel tftp://10.36.12.41/NetBoot/NetBootSP0/CasperNetboot.nbi/i386/mach.macosx --kernelcache tftp://10.36.12.41/NetBoot/NetBootSP0/CasperNetboot.nbi/i386/x86_64/kernelcache --options "rp=nfs:10.36.12.41:/private/tftpboot/NetBoot/NetBootSP0:CasperNetboot.nbi/NetBoot.dmg"
nvram boot-args="rp=nfs:10.36.12.41:/private/tftpboot/NetBoot/NetBootSP0:CasperNetboot.nbi/NetBoot.dmg"
nvram efi-boot-kernelcache='<array><dict><key>IOMatch</key><dict><key>BSD Name</key><string>en1</string><key>IOProviderClass</key><string>IONetworkInterface</string></dict><key>BLMACAddress</key><data>QGyPPmI8</data></dict><dict><key>IOEFIDevicePathType</key><string>MessagingIPv4</string><key>RemoteIpAddress</key><string>10.36.12.41</string></dict><dict><key>IOEFIDevicePathType</key><string>MediaFilePath</string><key>Path</key><string>NetBoot/NetBootSP0/CasperNetboot.nbi/i386/x86_64/kernelcache</string></dict></array>'
nvram efi-boot-file='<array><dict><key>IOMatch</key><dict><key>BSD Name</key><string>en1</string><key>IOProviderClass</key><string>IONetworkInterface</string></dict><key>BLMACAddress</key><data>QGyPPmI8</data></dict><dict><key>IOEFIDevicePathType</key><string>MessagingIPv4</string><key>RemoteIpAddress</key><string>10.36.12.41</string></dict><dict><key>IOEFIDevicePathType</key><string>MediaFilePath</string><key>Path</key><string>NetBoot/NetBootSP0/CasperNetboot.nbi/i386/mach.macosx</string></dict></array>'
nvram efi-boot-device='<array><dict><key>IOMatch</key><dict><key>BSD Name</key><string>en1</string><key>IOProviderClass</key><string>IONetworkInterface</string></dict><key>BLMACAddress</key><data>QGyPPmI8</data></dict><dict><key>IOEFIDevicePathType</key><string>MessagingIPv4</string><key>RemoteIpAddress</key><string>10.36.12.41</string></dict><dict><key>IOEFIBootOption</key><string>rp=nfs:10.36.12.41:/private/tftpboot/NetBoot/NetBootSP0:CasperNetboot.nbi/NetBoot.dmg</string></dict></array>'
