Hey,
I am trying to get the certs sorted out on our test 9.0 JSS, and I came across some old instructions that reference a hidden URL for accessing the internal CA on the JSS. Basically, it used to be just your JSS url with /ca.html added.
http://www.jamfsoftware.com/libraries/pdf/white_papers/Manually_Installing_the_JAMF_Software_Server.pdf
This does not work in 9.0. Is there another way to access the CA on a 9.0 JSS?
Thanks,
--Andy
Global Management > PKI
