I'm trying to create plist file for MS Defender to schedule a full scan, everyday at 8pm, but it doesn't seem to be working. Below is a copy my current plist. I've also tried the example given by Microsoft, but not luck.
If I try load it manually, I receive a "invalid property list" message.
"/Library/LaunchDaemons/com.microsoft.wdav.schedfullscan.plist: Invalid property list"
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN"
"http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.microsoft.wdav.schedfullscan</string>
<key>ProgramArguments</key>
<array>
<string>sh</string>
<string>-c</string>
<string>/usr/local/bin/mdatp scan full</string>
</array>
<key>RunAtLoad</key>
<true/>
<key>StartCalendarInterval</key>
<dict>
<key>Day</key>
<integer>0</integer>
<key>Hour</key>
<integer>20</integer>
<key>Minute</key>
<key>Weekday</key>
</dict>
<key>WorkingDirectory</key>
<string>/usr/local/bin/</string>
</dict>
</plist>
I also included the script to grant the following permissions:
#Grant Permission
/usr/sbin/chown root:wheel "/Library/LaunchDaemons/com.microsoft.wdav.schedfullscan.plist"
/bin/chmod 644 "/Library/LaunchDaemons/com.microsoft.wdav.schedfullscan.plist"
/usr/sbin/chown root:wheel "/Library/LaunchDaemons/com.microsoft.wdav.schedquickscan.plist"
/bin/chmod 644 "/Library/LaunchDaemons/com.microsoft.wdav.schedquickscan.plist"
#Start at boot
/bin/launchctl bootstrap system "/Library/LaunchDaemons/com.microsoft.wdav.schedfullscan.plist"
/bin/launchctl bootstrap system "/Library/LaunchDaemons/com.microsoft.wdav.schedquickscan.plist"
#Load and start the file
launchctl load /Library/LaunchDaemons/com.microsoft.wdav.schedfullscan.plist
launchctl start com.microsoft.wdav.schedfullscan.plist
