Self Service doesn’t install
  • October 22, 2021
  • 11 replies
  • 384 views
gadsden_flag
Hi
I’m trying to set up a BYOD environment besides our company owned devices. As shown here
With PreStage Enrollments it works like a charm but on the personally owned devices it doesn’t install at all. I followed this manual but it doesn’t work. All I got is an error, shown here
What is going wrong here? Thanks
Best answer by gadsden_flag
Are there any other apps you can try installing automatically?
If they come down we can narrow down the issue to just Self Service
I think I’m a step further. I deleted the app from the Mobile Device Apps and get it again from the Apple Business Manager. Unfortunately I forgot to add the App Config, but the app was installed immediately. So I deleted the app from my iPhone, put code to App Config and now the installation is pending since minutes.
  • October 22, 2021
Is there a reason you are manually installing Self Service? You can just set it to AutoInstall and this should work on DEP and User Enrolled devices.
gadsden_flag
  • October 22, 2021
First I tried to autoinstall. With the DEP it’s working. But when I have a personal device
it doesn’t install neither. I would be very happy to have an autoinstall. 😉
How to get there? I’ll give it a try.
Thanks.
BTW. Sorry, I’m very new to Jamf, so I have to ask many dumb questions.
  • October 22, 2021
Thanks.
No problem! You can navigate to Settings > Self Service > Mac OS (or iOS depends on the device) and select install automatically...
It should populate automatically on the MacOS side, but if it doesn't for some reason, I just put /Applications in the install field!
gadsden_flag
  • October 22, 2021
Yes, I found that. But on the Personal devices it doesn’t work. Maybe I did something wrong.
  • October 22, 2021
Can you post your App Configuration? Also when you are in Mobile Device Apps > Self Service Mobile for "Managed Distribution" do you see all your available licenses?
gadsden_flag
  • October 22, 2021
I did everything like here https://docs.jamf.com/10.33.0/jamf-pro/administrator-guide/Jamf_Self_Service_for_iOS.html
<dict> <key>INVITATION_STRING</key> <string>$MOBILEDEVICEAPPINVITE</string> <key>JSS_ID</key> <string>$JSSID</string> <key>SERIAL_NUMBER</key> <string>$SERIALNUMBER</string> <key>DEVICE_NAME</key> <string>$DEVICENAME</string> <key>MAC_ADDRESS</key> <string>$MACADDRESS</string> <key>UDID</key> <string>$UDID</string> <key>JSS_URL</key> <string>$JPS_URL</string><key>MANAGEMENT_ID</key><string>$MANAGEMENTID</string></dict>
I tried also with the real URL here
<key>JSS_URL</key> <string>https://myjamf.example.com</string>
I have some licenses here
I also added the MAID of the user of the personal device.
If you need more information, please ask. I want to get it running asap.
  • October 22, 2021
gadsden_flag
  • October 22, 2021
Thanks for your time.
Yes, other apps do install like expected. It’s only the Self Service. I don’t understand why the error message (first post) is in german. But it says the mobile device management request is not valid. I don’t know, what this means. Google cannot find anything about it. Maybe the original error message is different and the translation is bad so I can’t find any hits on Google.
MikaelDez
  • October 22, 2021
Edited my response because I missed that this was regarding iOS, not macOS
gadsden_flag
  • October 22, 2021
gadsden_flag
  • October 23, 2021
Now I try with another device and get the same message again. Very strange.
