Jamf Pro 10.34.0 Beta 2 is now available!
  • October 25, 2021
  • 50 views
scafide
Forum|alt.badge.img+21
Jamf Pro 10.34.0 Beta 2 introduces a lot of really great quality of life improvements for Jamf Pro Administrators.
We've made it easier to verify your cloud identity provider's attributes are mapped correctly with a redesigned user interface, you can now safelist apps from being restricted by the Jamf Parent and Jamf Teacher apps, you can better control remotely updating macOS on managed devices, shared iPad temporary sessions have been implemented, and more!
How to join the beta :
We’ve also made some changes to the Beta enrollment process with our new Jamf Nation platform. Please enroll in the Beta Program under Product Feedback at account.jamf.com. Once you’re enrolled you’ll see a link to the Beta Forum. There will be a short delay between enrollment and Jamf Nation beta forum access - you will receive a notification in Jamf Nation to join the beta forum.
If you have any questions please email
beta@jamf.com
As always, the beta program is operated under non-disclosure, so please do not share any information regarding your testing on any public forum, including the non-beta sections of Jamf Nation. Use the Jamf Nation beta discussion area or contact Jamf via beta@jamf.com with any questions regarding the beta.
Thank you to all those who participate in the program!
Liam_Donnelly
  • October 26, 2021
Shared iPad additions are long over due! Glad they have finally made
  • October 29, 2021
Hi scafide,
thanks for Beta 10.34.0. Does "...you can better control remotely updating macOS on managed devices..." mean Jamf Pro 10.34.0 will support Apple's InstallLater MDM command for enforcing macOS Updates?
I think this command will make enforcing macOS updates much more easy for us administrators.
