I have turned turned off Apple TV updates but has anyone noticed or have an issue when someones goes to airplay the user gets a message to enter the airplay passcode and then when then on the projector goes black but the laptop looks like it's projecting. After the user restarts their laptop and/or desktop they are then able to airplay successfully.
Is there an easy fix because currently factory resetting the MacOS has done the trick except for one that has a repeated issue. Is this a bug in MacOS or in the TVOS most of the Apple TVS we have are running TVOS 15 and some running older TVOS 14 and one running TVOS 13 I also posted on Apple Community for further information
