Monterey - Account Name During Setup doesn't allow for @ character
  • October 27, 2021
  • 32 views
Sdwick
After a clean install of Monterey, I enrolled an M1 MacBook Air that is apart of our prestage environment within Apple Business Manager. During the initial account setup we are trying to utilize email address for the account name and on previous versions of MacOS have not had any issues. Whenever I try to edit the account name field the @ disappears and any attempt to replace it yield the same results. I am curious if anyone else has experienced this behavior as well.
Best answer by Sdwick
Issue seams to now be resolved I have been able to create users accounts including the @. Apple must have resolved the issue.
MikeMikeMike
  • October 27, 2021
Can't use @ in the account name, but you can use it in the full name field.
Sdwick
  • October 27, 2021
This account was created via Setup Assistant after a clean install on Big Sur. However I can't create a new user with the @ on either OS in the full name.
Sdwick
  • November 3, 2021
