Hello,
I am trying to push Google Drive from Jamf, however when it asks for permissions (I am not at the point of making PPPC or system/kernal extensions), but when this pop up comes up:
"To approve, open System Preferences > Security & Privacy. Click the lock to make changes, and enter your administrator ID and password. Under the “General” tab, you’ll see that some system software requires your attention before it can be used. After you give approval, restart your computer."
There is no approval option.  I have restarted and reinstalled a bunch of times.
Has this happened to anyone else, or have any recommendations?
I have tried this on Mojave, Catalina and Big Sur Intel Macs and all have the same issue.
You can find the solution to this issue here:
https://community.jamf.com/t5/jamf-pro/install-google-drive-file-stream-system-extension-blocked/m-p/250799/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtWSlExRERTMlZYMEhVfDI1MDc5OXxTVUJTQ1JJUFRJT05TfGhL#M233741
