JAMF Pro and Yubikeys
  • November 8, 2021
  • 168 views
Hi JamF Community Members,
We are required to use Yubikey's as a MFA option. Ideally we'd like to push this configuration through Jamf Pro. Can anybody point me in right the direct or provide a link to the relevant documentation?
  • November 8, 2021
This is something I've been looking into as well, as my organization is looking to implement YubiKey as an MFA solution. I don't have the full solution built yet, but here's the documentation I've dug up so far:
Jamf Pro Overview doc: https://resources.jamf.com/documents/technical-papers/macos-smart-card-overview.pdf.
YubiKey macOS setup guide: https://support.yubico.com/hc/en-us/articles/360013790219-Getting-Started-with-the-YubiKey-on-macOS
  • October 4, 2022
@Rob01  & @jcaleshire  Any ideas how to help user having locked smartcard to unblock his smart card at login?
Context:  MacOs detects that smartcard is bloked but doesn't show puk prompt. Yubikey support hasn't provided a professional solution.
Workaround:
1) unlock the locked key using yubikey another manager on another computer/mac !!!!
2) Unscope MDM smartcard config if the mac is still networked !!!
=> I need business solution that enable user to quickly unlock his yubikey and login in.
