I have been updating all the iPads in my department for some time now. I noticed since last week when I send the Mass Update OS command, it's not sending even if it says "Remote Command Sent". I go into the Pending Commands, it's not there. Anyone else having this issue?
I sent the "Clear Passcode" command and that works. It's only the Update OS Command that doesn't.
Be the first to reply!
