I'm working on building a Title Editor entry for the Barco MirrorOp app. On its site, Barco lists the latest version as 2.5.4.90. Unfortunately, the app's Get Info window (and Jamf app inventory) only shows the main version (2.5.4). I found in the app's Info.plist file that the version is split between two strings, "CFBundleShortVersionString" (2.5.4) and "CFBundleVersion" (89, 90, etc.). I've gotten the below script cobbled together so far (from another question I found here), but could use a little help figuring out how to merge the two strings together so the full version number gets reported.
PrefPanePath="/Library/PreferencePanes/Retrospect Client.prefPane"
if [ -e "$PrefPanePath" ]; then
result=$(defaults read "${PrefPanePath}/Contents/Info.plist" CFBundleVersion)
result="Not Installed"
