An Alternative to the Jamf Intune Integration (No more jamfAAD pop-ups)
  • November 19, 2021
  • 32 replies
  • 245 views
bwoods
If any of you are tired of your users receiving jamfAAD pop-ups, I would highly recommend transitioning to device identification using certificates. This method of conditional access allows you to control conditional access directly from your Jamf Pro server. Access is simply determined by the presence of your certificate. (This does require your users to have E5 licenses)
The certificate is deployed via configuration profile...so no more manual registration either. Perfect for zero-touch deployments. To stop the pop-ups unload or delete any launchAgents related to the jamfAAD Agent.
You can read more about this process here
  • November 22, 2021
This is definitely worth looking into. I wonder if an MS Defender for Office Plan 1 or Enterprise Mobility + Security E3 license is enough. Picking up E5's for everyone is definitely not cheap.
bwoods
  • November 23, 2021
Hi @Levi_ , I've got more useful information on Microsoft Cloud App Security here.
piotrr
  • November 24, 2021
Will look into this, thanks bwoods. We're already at that license with Defender deployed.
bwoods
  • January 31, 2022
#!/bin/bash # Disable jamfAAD # Brandon Woods # January 2022 # This script will remove all jammADD components and disable the microsoftCAEnabled preference key # Delete JamfAAD.app rm -rf /Library/Application\\ Support/JAMF/Jamf.app/Contents/MacOS/JamfAAD.app # Delete JamfAAD symbolic link rm -rf /usr/local/jamf/bin/jamfAAD # Unload com.jamf.management.jamfAAD.agent.plist launchctl unload -w /Library/LaunchAgents/com.jamf.management.jamfAAD.agent.plist # Delete com.jamf.management.jamfAAD.agent.plist rm -rf /Library/LaunchAgents/com.jamf.management.jamfAAD.agent.plist # Unload com.jamf.management.jamfAAD.clean.agent.plist launchctl unload -w /Library/LaunchAgents/com.jamf.management.jamfAAD.clean.agent.plist # Delete com.jamf.management.jamfAAD.clean.agent.plist rm -rf /Library/LaunchAgents/com.jamf.management.jamfAAD.clean.agent.plist # Disable microsoftCAEnabled preference key defaults write /Library/Preferences/com.jamfsoftware.jamf.plist microsoftCAEnabled -bool false exit 0; ## Success exit 1; ## Failure
  • March 30, 2022
@bwoods - Thanks for the Tip. We have been getting a lot of user complaints since rolling out Intune Integration. I would love to make those go away.
I have few question:
  • When you are deploying the Config Profile to install the certificate are you installing at the Computer level or User level?
  • Are you enabling "Allow all apps access" for the certificate?
  • Are there any special information needed in the Certificate Subject or Subject Alternative Name?
bwoods
  • March 31, 2022
@TimArnold. I found that system and user certs work for macOS. I would recommend using a system cert. If your have ADCS or SCEP configured for Wireless you don't even need to deploy a cert. Just upload the Root and Intermediate cert of your ADCS/SCEP cert and the policy will use the PKI cert for conditional access.
I do have "All all apps access" enabled for the certificate.
My San is the same as my wireless cert because my wireless cert and conditional access cert are one in the same. (Let me know if this doesn't make sense.)
Reach out on the #jamf-intune-integration MacAdmins Channel. My username is brndnwds6.
  • April 12, 2022
This looks real cool.  Going to add this to the POC we are doing.
Is there any documentation to create requirements to get the cert from the config policy?  The link shows how to setup a CA policy in Azure that requires the presence of the cert to get access, but I do not see where we can leverage Jamf in a way that would only pass those certs to machines we deem compliant.  I suppose Smart groups would be the best solution?
  • February 8, 2023
@bwoods we don't have ADCS/SCEP but we deploy CA and intermidiate cert with config profile to the endpoint which we have to update every year. So you are saying same cert need to be on Azure? And then remove JamfAAD to avoid that pop up? is that means machine don't need to register thorugh JamfAAD if both system (Azure and Jamf) has those cert? Then I guess we don't need to deploy company portal as well right? Please clarify.
bwoods
  • February 9, 2023
I basically gave this to my security team and we began testing with a dummy certificate. I would suggest using a PKI cert because they automatically renew:
Conditional Access - device identification using certificates - ChrisOnSecurity
  • February 23, 2023
@bwoods
I was checking that JamfAAD presence before removal. I just found only one location JamfAAD presence which is:
/usr/local/jamf/bin/jamfAAD. Other than that no where i found any JamfAAD presence on my test machine. But still I am getting pop up that same error. So is that will help me to run your script? And another thing for your information we are not using Jamf connect, we are using Jamf Pro. As per Microsoft JamfAAD is for Jamf connect not for Jamf pro. Any comment on this please?
bwoods
  • February 23, 2023
@sharif_khan I noticed that some of my users started getting prompted again a few weeks ago. Jamf made changes to the "jamfAAD.app". They changed the name to the "Jamf Conditional Access.app".
  • February 23, 2023
@bwoods Thanks for reply. Here I make some changes which I think need to work your script.
rm -rf /Library/Application\\ Support/JAMF/Jamf.app/Contents/MacOS/Jamf\\ Conditional\\ Access.app
But couldnot find any plist for following commands
So do we need to remove these .plist or I am missing something?
Another thing is before write to com.jamfsoftware.jamf.plist, we can add a check point as below
if [ $(defaults read /Library/Preferences/com.jamfsoftware.jamf.plist microsoftCAEnabled) != 0 ]; then
echo "No change required"
bwoods
  • February 23, 2023
Ah yes the script, I found that just using a jamf restriction works much better.
  • March 15, 2023
Hi, I'm currently setting up and evaluating MCAS for Conditional Access. We've set up the policy as described and it blocks app login when the certificate is not present. When the certificate is present, it doesn't block... but it the (office) apps is failing to authenticate the user.
bwoods
  • March 15, 2023
I don't know if this helps, but we had to create an exception group in Azure AD that excludes members from all other conditional access policies. Now we just add them to the group during imaging.
  • March 20, 2023
I have a question regarding Jamf and Intune integration. What is actual benifit with that besides Inventory information? Can any one give me some detail informaiton what other benifit we can gain with that integration.
piotrr
  • March 24, 2023
Conditional access and compliance monitoring in Azure  and Intune, which enables risk-based sign-in management.
  • May 12, 2023
We have just setup "Device Compliance" (the new way) according to the documentation here: https://learn.jamf.com/bundle/jamf-pro-documentation-current/page/Device_Compliance.html in Jamf and are testing it. And for some reason, this (picture below) part doesn't come up sometimes and when it doesn't we have no clue on how to trigger it again. I noticed when i reinstalled one of my test machines, it didn't appear upon registering with Company Portal, another time it appeared and all was working perfectly fine. Now it doesn't matter if we delete the MS-Organization-Access certificate and the key Microsoft Workplace Join Key and then rerun registration with company portal. Any help is much appreciated!
  • May 12, 2023
Hi @nadsad
You can create a EA to confirm that JamfAAD installed or not with the following
#current logged in user variable
currentuser=`stat -f "%Su" /dev/console`
#variable for current logged in user AAD ID cert. and WPJ key
AAD_ID=$(su "$currentuser" -c "security find-certificate -a -Z | grep -B 9 "MS-ORGANIZATION-ACCESS" | awk '/\\"alis\\"<blob>=\\"/ {print $NF}' | sed 's/ \\"alis\\"<blob>=\\"//;s/.$//'")
echo "<result>$AAD_ID</result>"
If that is showing and ID then you should check another thing which you have to be full Azure Admin AD and authenticate Jamf Pro instance from Azure AD by login from here
Settings -> Global -> Conditional Access -> macOS Intune Integration -> Jamf Native MacOS Connector Consent and click on Open administrator consent URL
That will take you to Azure AD and login there and approve Jamf pro. That should resolve your JamfAAD pop up issue.
  • May 12, 2023
Well that's the thing the consent is done and it's successful (see below picture) and we are using the Settings -> Global -> Device Compliance and not Conditional Access. So it worked first time then i reinstalled my computer and this time the JamfAAD thing didn't show up when i ran the registration with company portal, and you can see i have the key. But what i don't see which usually is created when JamfAAD pops up is /Users/$loggedInUser/Library/Preferences/com.jamf.management.jamfAAD.plist but i don't see this. I also see the device under User -> Devices in Azure. But without the JamfAAD authentication it wont work and iv'e been trying to figure out how to trigger it again but can't figure it out :(
  • May 12, 2023
Ok just randomly I just reran registering with company portal and now the JamfAAD popped up and now this was also created. But i tried registering many times, no clue of why it worked now... pretty random and really bad if it happens in production.
  • May 15, 2023
Hi @nadsad
I have no idea where you got device compliance? In my case Jamf pro (V: 10.46.0) show settings -> Conditional Access. Couldn't find Device Compliance. Can you please direct me how you got that?
  • May 15, 2023
Hi @nadsad
Here:
But i am back again with the issue. So I have 2 test computers, I reinstalled both of them. Did the registration via Self-Service with the policy and payload "Microsoft Device Compliance" but the JamfAAD authentication never shows up which is supposed to show up once you press "Done" after the registration is done... anyone have any ideas?
  • May 15, 2023
Here:
Gotta add though that our instances are not upgraded yet to 10.46, we have 10.45 still. They will be upgraded between may 19-20.
  • May 15, 2023
And btw, I would assume you're aware that the "Conditional Access" will be discontinued in the future?
