Remove User Level Configuration Profile
  • November 30, 2021
  • 20 replies
  • 140 views
BookMac
Hello, everyone,
we added our existing MacBooks to jamf via UIE. The devices still have manually installed user profiles under System Settings - Profiles. Certificates were distributed with the configuration profile. Is there a way to uninstall this profile via jamf?
Cheers
Best answer by BookMac
Ah, Ok. I didn't know it had that. So in that case you may be able to script removing this by passing the actual profile password after that flag. I would give that a try. It seems to me that's the reason why you haven't been able to remove it in your policy. It's looking for that removal password.
i think we got it. this script in a policy removed the profile
username=$( scutil <<< "show State:/Users/ConsoleUser" | awk -F': ' '/[[:space:]]+Name[[:space:]]:/ { if ( $2 != "loginwindow" ) { print $2 }}' )
loggedInUID=$(id -u "$username")
/bin/launchctl asuser $loggedInUID sudo -iu $username profiles -R -p CompanyCertificates -z password
exit
junjishimazaki
  • November 30, 2021
Hi, can you explain what you mean by "manually installed config profiles"?
BookMac
  • November 30, 2021
Before we had jamf we installed a configuration profile on every mac by double click the profile and insert the admin credentials for the installation.
junjishimazaki
  • November 30, 2021
Ah I see, thank you for clarifying.  Then yeah if it was manually installed then you have to manually uninstall the profiles.
You can try the script route to search for the config profile UUID and then remove it.
You might have to use the command sudo profiles -R -p profileidentifier
BookMac
  • November 30, 2021
I'm getting the error:
profiles remove for identifier:'xxx' and user:'root' returned -205 (The operation couldn't be completed. (CPProfileManager error -205.))
To uninstall the profile a pasccode is required. Could this be a problem?
junjishimazaki
  • November 30, 2021
How did you obtain the profile identifier?
BookMac
  • November 30, 2021
sudo profiles list -all
then I get the user and the certificate as output:
givenname.surname[1] attribute: profileIdentifier: CompanyCertificates
junjishimazaki
  • November 30, 2021
Sorry for the delay, I got busy. Hmmm, that is correct. Did you run the removal as a script or just in the terminal to test it out?
BookMac
  • November 30, 2021
just in terminal to test it out. if i delete the configuration profile in system preferences i must insert a passcode and it's gone. But i don't want to connect to every mac and insert the passcode to delete it
junjishimazaki
  • November 30, 2021
Passcode or password?
BookMac
  • November 30, 2021
Password, sorry
  • November 30, 2021
I'm not understanding this. Don't you have Jamf Pro? That's a perfect scenario for using Jamf since it runs scripts and commands as root. If you put that into a script and deploy it it should not require you entering any passwords.
BookMac
  • December 1, 2021
yes, we have jamf pro. i've tried a policy with "Files and Processes" and the execute command "sudo profiles -R -p CompanyCertificates
The result of the policy is the same like in terminal:
Result of command:
profiles remove for identifier:'CompanyCertificates' and user:'root' returned -205 (The operation couldn’t be completed. (CPProfileManager error -205.))
BookMac
  • December 1, 2021
password
junjishimazaki
  • December 1, 2021
Result of command:
When you run sudo profiles -R -p in the terminal with the profile ID does it ask for a password?
BookMac
  • December 2, 2021
exactly. this is what it looks in terminal:
username@devicename ~ % profiles -R -p CompanyCertificates
Enter the profile removal password:
After the password the profile is gone. the user is no admin user.
  • December 2, 2021
Ok, I see what’s going on here. Your profile has a removal password applied to it. Meaning the password is something separate from an admin password.
if this is the case, the only way I believe you can automate this would be with an expect script. I don’t think the ‘profiles’ command has a flag for using a removal password, not that I’m aware of anyway. You can look thru the man page for it to see.
junjishimazaki
  • December 2, 2021
In the man pages for Profiles there is a flag to pass a password which is -password.
  • December 2, 2021
BookMac
  • December 2, 2021
exit
  • June 14, 2023
@mm270 Explain what is removal password here as I'm also facing an issue in removing the profile via shell script.
