Script to Replace UserName with EA "Last User Logged In"
  • December 7, 2021
  • 13 replies
  • 105 views
Hi I am looking for a script to replace the Username in the inventory section with the Extension Attribute of "Last User Logged In".  In addition to add "@companyX.com" as a suffix to the user name.  This would help me greatly in getting Asset inventory for my company via Azure.  I am getting the Last User Logged In by Extension Attribute.  So if the "Last User Logged In" is john.doe , take john.doe and add @companyX.com and fill the Username in the inventory section as john.doe@companyX.com.  This would then poll Azure and I would get all the data I need.  Still looking for a way to not manually update the username field when deploying a Mac to another user.  My scripting skills are limited, apologies. Thanks,
JT
Best answer by robjschroeder
#!/bin/bash # Define domain suffix to add to username domain="companyX.com" # Get the last user of computer lastUser=`defaults read /Library/Preferences/com.apple.loginwindow lastUserName` if [ $lastUser != "" ]; then username=$(echo "$lastUser"\\@"$domain") # Update Computer Inventory Record jamf recon -endUsername $username else echo "No Logins, exiting..." fi
Forum|alt.badge.img+15
  • December 7, 2021
#!/bin/bash # Get the last user lastUser=$(defaults read /Library/Preferences/com.apple.loginwindow lastUserName) echo "Running recon for ${lastUser}..." jamf recon -endUsername "${lastUser}"
  • December 7, 2021
If you want to manually add a domain suffix to lastUser:
lastUser="$(defaults read /Library/Preferences/com.apple.loginwindow lastUserName)@example.com"
  • December 14, 2021
  • January 19, 2022
@robjschroeder   This work great!!!   Thank you so much!
  • January 19, 2022
Awesome! I'm glad to see it worked for you!
NickGuru
  • July 27, 2022
this would of worked if our company email standard was, example JDoe@company.com, but our email standard name is Joe.Doe@company.com . Good thing the policy only went out to about 30 users. I'll just click on each computer and manually enter their email address, then hit the search icon and it will find them and populate, their name, email, department, etc.
Lakshmana
  • August 1, 2023
Hi
I need the help for the above script.The users are in Azure and need to update the last login user automatically on daily basis in Asset Inventory.I am new to Jamf Pro.Can anyone help me whether we need to put the above shell script to be run in all the user machine and then this will update it for the Asset inventory ?
Hi
Hey @Lakshmana ! You would need to run this script with a policy once per day to populate the user and location username with the logged in user. You would also need to make sure you are collecting ldap information on your computers. That setting is in Computer Management > Inventory Collection
Lakshmana
  • August 2, 2023
domain="domain.com"
if [ "$lastUser" != "" ]; then
# Extract the username without the domain suffix
username=$(echo "$lastUser" | cut -d "@" -f1)
# Add domain suffix to create the email address
email="$username"@"$domain"
sudo jamf recon -endUsername "$username"
# Set the email address for the user
sudo jamf recon -email "$email"
I am trying this method to get the last username information.But the username information is not always correct.Example)firstname.last@domain.com is the email id means i am getting this firstname.last as the username but for some users we have username@domain.com this becomes issue for me.
Example)User who logged in FirstnameLast is shown here because of this @domain.com is having error for me.
Issue 1)We have the email like this format for some users(firstname.letter@domain.com
Issue 2)We have other emails like in this format for some users(username@domain.com)
Do we have any other way to rewrite this script validate the username information with the Azure ?
I also in need to get the Full Name and Position of the user information into the Jamf if possible.
domain="domain.com"
Do you have Azure AD connected via Cloud IdP in Jamf? You’ll also need the setting to collect LDAP data in your Computer Inventory Collection. But provided you have those two set up, it should pull in the users details into the computer inventory record after recon, provided there is a username in the record.
Lakshmana
  • August 2, 2023
@robjschroeder  Yes I have connected my Azure AD via Cloud IdP in Jamf.How to do the settings with the LDAP data ?
Azure does not support LDAP here as far as I know.I have the users sync in the Google G-Suite which have LDAP here
https://learn.jamf.com/bundle/jamf-pro-documentation-current/page/Computer_Inventory_Collection_Settings.html
Lakshmana
  • August 2, 2023
I need one more help here.The users profile in the mac machine is not same as username of their email id.If we change it through a shell script that will create a new folder.how to make the changes in backend without making the data loss for the user folder in any case if its possible to do so ?
