I've included a command in the DEPNotify-Starter script which using API's connects to the server and pulls down Departments the script itself appears to work fine, checking the logs it is pulling down the Departments correctly, I'm unsure how to display the contents of that variable within DEPNotify using the DEPNotify-Starter script, so the users can select from a drop down list. If/when I can get this working I plan on doing the same for Buildings.
Thanks
