I am in the process of designing a workflow to refresh for our M1 Macs in our computer labs (30 Mac each). The goal will be to erase and upgrade from Big Sur to Monterey. I have a few options:
1. Deploy OS installer, run this
echo 'P@55w0rd' | '/Applications/Install macOS Big Sur.app/Contents/Resources/startosinstall' eraseinstall
--agreetolicense --forcequitapps --newvolumename 'Macintosh HD' --user adminuser --stdinpass2. Use mass actions to send a OS Upgrade MDM command to the latest version, once done, send a Wipe Device command (EaCS)
I prefer option 2 since I do not need to send credentials over, but JAMF does not offer mass actions for wipe device. I am also thinking about doing in API, but involves a R&D hours and likely above my skill set.
Do you guys have a different workflow for this type of work?
