Extension Attribute to get AirPlay Receiver status and script/command to disable it
  • January 11, 2022
  • 40 views
karthikeyan_mac
Forum|alt.badge.img+20
I am looking for way to get the status of AirPlay Receiver and also command/script to disable it. I do not want to disable  through config profiles. Thanks.
ljcacioppo
  • January 11, 2022
Personally, I use a config profile, but I believe this setting is in a ByHost Preference so you should be able to check like this:
defaults -currentHost read com.apple.controlcenter AirplayRecieverEnabled
And disable like this:
defaults -currentHost write com.apple.controlcenter AirplayRecieverEnabled -bool false
Note: Yes, the word "Receiver" is purposefully misspelled in the script because the key is misspelled
  • May 13, 2022
Hello @ljcacioppo ! Where is this key stored exactly?
karthikeyan_mac
  • May 16, 2022
Its stored in ~/Library/Preferences/ByHost/com.apple.controlcenter/{UDID}.plist
