Why isn't my Computer Naming script working
  • January 12, 2022
  • 9 replies
  • 68 views
The prefix is showing up on the device, but it's not pulling down the serial. I've even tried a few commands I've seen on these forums, and it still won't grab the serial. I am learning scripting, and only know basic commands. I took over for the previous sys admin who left, and he could never get the script to work either.
MODEL=$(sysctl hw.model)
if [[ $MODEL == *"Book"* ]]
then
PREFIX="TRML-"
PREFIX="TRM-"
SERIAL=$(ioreg -rd1 -c IOPlatformExpertDevice | awk -F'"' '/IOPlatformSerialNumber/{print $7}')
COMPUTERNAME="${PREFIX}${SERIAL}"
/usr/sbin/scutil --set ComputerName $COMPUTERNAME
/usr/sbin/scutil --set LocalHostName $COMPUTERNAME
/usr/sbin/scutil --set HostName $COMPUTERNAME
Best answer by karthikeyan_mac
ioreg in your script does not seem to be working. Change it as below. You can use system_profile command as well. Add update inventory in the policy to report back the new name.
ioreg -rd1 -c IOPlatformExpertDevice | awk -F'"' '/IOPlatformSerialNumber/{print $4}'
dwbergstrom
  • January 12, 2022
Here's a couple alternatives to the ioreg command to get the serial number if you wanted to try them in its place:
system_profiler SPHardwareDataType | grep "Serial Number (system)" | awk '{ print $4 }'
or
system_profiler SPHardwareDataType | awk '/Serial/ {print $4}'
Forum|alt.badge.img+15
  • January 12, 2022
I would suggest adding a sleep 1 between your scutil commands. Otherwise you may see that your name change didn't fully work.
/usr/sbin/scutil --set ComputerName $COMPUTERNAME sleep 1 /usr/sbin/scutil --set LocalHostName $COMPUTERNAME sleep 1 /usr/sbin/scutil --set HostName $COMPUTERNAME sleep 1
  • January 13, 2022
I think you need the command jamf recon for uploading the new computer name to Jamf Pro. Otherwise the computer name will be changed back after next check in.
karthikeyan_mac
Forum|alt.badge.img+20
  • January 13, 2022
  • January 13, 2022
As @karthikeyan_mac mentioned, you have the wrong column being printed in the awk section with your original command. Change it to print $4 like noted above and it should pull the serial number. The other alternative ways to grab the serial mentioned by others here should also work.
Tangentism
  • January 13, 2022
or use:
jamf setComputerName -name $COMPUTERNAME
  • January 13, 2022
this fixed it. Thank you so much!!!!
  • January 13, 2022
I got it working with a different ioreg command, but went ahead and added sleep between each command to avoid any possible issues. Thank you for the tip.
  • January 19, 2022
The jamf binary can do this for you without even performing a lookup.  "/usr/local/jamf/bin/jamf setComputerName -useSerialNumber"
