Configuration Profile to "Enable Screen Recording" no longer functions correctly under Monterey
  • January 13, 2022
  • 181 views
We have found that on Monterey devices, using a previously working (as in worked on Big Sur) configuration profile to enable screen recording for Google Chrome, Slack, and Zoom no longer works correctly. To explain, the config places the three under Screen Recording in the privacy menu, allowing the standard user to checkmark them. For the profiles, we tried both enabling and disabling "Big Sur compatibility".
Now when attempting to share the screen, the applications still prompt for the user to checkmark the options, even though they are already check marked.
When we manually add the three applications through Privacy, they function normally.
Has anyone else run into this?
I've included the PPPC for Zoom, as an example
Identifier: us.zoom.xos Identifier Type: Bundle ID Code Requirement: identifier "us.zoom.xos" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = BJ4HAAB9B3 App or Service Access ScreenCapture Allow Standard Users to Allow Access
  • March 24, 2022
Yes for chrome I think this is related to this bug.  Still looking for an easy solution.
  • September 13, 2022
Hi, Can you Please explain how to add manually the three applications through Privacy
Below is a screen shot of the config profile I am using for Zoom.
