Digital Guardian Deployment Jamf....
  • January 13, 2022
  • 6 replies
  • 90 views
Might someone have some insight and clarity on how to deploy Digital Guardian via Jamf.
I have a lot of experience with security agents in Jamf: Crowdstrike, FireEye, Tanium, Netskope, but it seems Digital Guardian is a mystery.
I have a shell script and I believe the are some Config Profiles to configure. It could be extensive or rather straight forward, but from the version 7 documentation it's not clear at all. And I believe version 8 is for Big Sur 11.6x and Monterey, using SYSEX.... Thanks so much....
  • July 27, 2022
Hello, I am having to deploy digital Guardian. Did you figure this out? I am at a loss as to how to get this deployed.
Yes, I figured it out. It was months ago. Ping me in Slack > MacAdmins...
  • August 16, 2022
We are replacing Endpoint Protector with Digital Guardian and I was able to make a package/script that uninstalls EPP then install DG, but the system extension is missing, any idea?
  • December 8, 2022
Hi Please help me to deploy this on Mac system through jamf
  • December 8, 2022
Please help me to share the DG script to install the endpoint agaent
  • December 20, 2022
I able to deploy DigiTal Gaurdian 8.0 to macOS Monterey via Jamf. But u have to get the install from DG support team and need to create .pkg. U need to partner with your security team
