Enable Screen Mirroring show in menubar
  • January 18, 2022
  • 9 replies
  • 123 views
Our fleet has just jumped from Catalina to Monterey and our users are struggling to locate the screen mirroring "Show in menu Bar" tickbox.
Ideally I would just like a script to enable this or our users.
I have tried
defaults write ~/Library/Preferences/ByHost/com.apple.controlcenter.plist ScreenMirroring -int 18
but it doesn't seem to work.
weirdly sound and bluetooth work though which are controlled inside the same plist.
e.g: defaults write ~/Library/Preferences/ByHost/com.apple.controlcenter.plist Sound -int 18
anyone got any ideas how the ScreenMirroring preference can be set via terminal script?
Cheers,
ES
Best answer by scottb
@elliots :
I found this in the MacAdmins slack...credit to @nstrauss - noting it's "per user":
#!/bin/zsh logged_in_user=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name 😕😕 && ! /loginwindow/ { print $3 }') user_home=$(dscl . -read /users/$logged_in_user NFSHomeDirectory | cut -d " " -f 2) sudo -u "$logged_in_user" /usr/bin/defaults write "$user_home"/Library/Preferences/ByHost/com.apple.controlcenter.plist ScreenMirroring -int 18 sudo -u "$logged_in_user" /usr/bin/defaults write "$user_home"/Library/Preferences/com.apple.airplay.plist showInMenuBarIfPresent -bool true sudo killall "ControlCenter"
Works here in macOS 12.2 beta I'm running, so give it a shot....
  • January 18, 2022
Update:
I have managed to enable the tickbox with:
defaults write com.apple.airplay showInMenuBarIfPresent -bool true
However I have another hurdle. Is it possible to change from the default: "when active" to "always" so it always displays in the menubar?
ES
scottb
  • January 18, 2022
@elliots :
scottb
  • January 18, 2022
@elliots :
Dang it...where the "smiley" is, change to : / (with no space in between)!!!
Someone tell me why pasting into code gives me emojis?  Or rather, how do I stop that!
  • January 19, 2022
Oh Thankyou! that worked a treat.
CalleyO
Forum|alt.badge.img+15
  • Employee
  • January 19, 2022
@scottb  Apologies, Scott, this is a bug and we are working to resolve it as quickly as possible.  😀
scottb
  • January 19, 2022
Thank you, @CalleyO - I meant to file it and forgot!  Appreciate the heads-up.
Forum|alt.badge.img+22
  • February 16, 2023
@elliots :
Edit: NM, I didn't see the comment about the inadvertent smiley face! All good now, thx for this!!
I'm getting an error when running the script, can you give a look for a scripting novice?
Script result: awk: syntax error at source line 1 context is /Name � && ! /loginwindow/ >>> { <<< awk: bailing out at source line 1 usage: sudo -h | -K | -k | -V usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user] usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command] usage: sudo [-AbEHknPS] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>] usage: sudo -e [-AknS] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ... usage: sudo -h | -K | -k | -V usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user] usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command] usage: sudo [-AbEHknPS] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>] usage: sudo -e [-AknS] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
  • January 30, 2024
@elliots :
Sorry, I didn't understand that "smiley" edit.
I get the same error as @TomDay
  • January 30, 2024
@itibsolution give this a try:
#!/bin/zsh logged_in_user=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name / && ! /loginwindow/ { print $3 }') user_home=$(dscl . -read /users/$logged_in_user NFSHomeDirectory | cut -d " " -f 2) sudo -u "$logged_in_user" /usr/bin/defaults write "$user_home"/Library/Preferences/ByHost/com.apple.controlcenter.plist ScreenMirroring -int 18 sudo -u "$logged_in_user" /usr/bin/defaults write "$user_home"/Library/Preferences/com.apple.airplay.plist showInMenuBarIfPresent -bool true sudo killall "ControlCenter"
