Trying to configure the clustering from on-prem server to Jamf DMZ external server windows based env
where do I configure the firewall rules on-prem or on the Jamf DMZ instances?
@NisarFawad Your firewall settings aren't done in Jamf Pro, those will have to be done by the network team that manages your firewall. As for configuring the Jamf Pro instance in the DMZ, https://docs.jamf.com/technical-articles/Installing_a_Jamf_Pro_Web_Application_in_the_DMZ.html is a good source of info.
@sdagley do I need the web application to configure or the Memcached in the DMZ?
@NisarFawad If you're planning on using memcached servers (I think they're still optional, or at least they were before my environment was moved from on-prem servers) then I'd expect you'd want them inside your firewall. The only Jamf Pro related servers required in your DMZ are the JSS instance (or instances if you're running a load balancer in front of them), and your public Distribution Point server.
Speaking of DPs... If you're using SMB connections to your internal DPs from Mac endpoints then you'll definitely want to move to HTTPS as publicly exposing SMB ports on a DMZ server is not a good idea.
Thanks, @sdagley. I'm trying to configure the current on-prem server to talk with my external server SQL DB (in the DMZ), which is the clients get the patches and 3rd party software updates without connecting to VPN.
Primarily should be the DMZ server, and secondary will be the internal JSS server.
I hope that makes sense to you.
(Replied to wrong part of thread)
@NisarFawad That's backwards. Primary JSS node, MySQL server, and Primary DP should be on internal network. Only the Client JSS node and public DP should be in your DMZ.
@sdagley, Trying to locate this line on the external DMZ web application when I add the internal keystore cert in the external instance the DMZ won't work.
should I remove the DMZ current cert or where can change that on the server.xml file?
  1. Copy the certificate keystore file from the internal server to the external server.
  2. Modify the server.xml file on the external server to point at the keystore file by locating the Connector Port element and adding the following lines:
    keystoreFile="/path/to/keystore-file"
    keystorePass="changeit"
@NisarFawadYou need the .keystore file from your Primary (Internal) JSS copied to the DMZ JSS so that it's using the same certificate and the instructions you reference should be clear on that. If you're asking exactly where the keystore can be found, it varies by the OS you're running. For RHEL, it used to be in /usr/local/jss/tomcat/ but I don't know if that has changed (it's been a while since I've used an on-prem JSS install)
@sdagley found the Keystore cert under the C:\\Program Files\\JSS\\Tomcat\\certs\\.keystore.
My question is regarding the server.xml file that needs to be tweaked too. I'm not sure where and which part I should change the instruction said the following. I can't find the line or step 3, the Connector Port element on the external server.xml file.
  1. Copy or make a note of the Keystore password from the server.xml file on the internal server. It should look similar to the following:
  2. Copy the certificate Keystore file from the internal server to the external server.
  3. Modify the server.xml file on the external server to point at the Keystore file by locating the Connector Port element and adding the following lines:
@NisarFawad Somewhere in the server.xml file for your DMZ JSS (which should be located at C:\\Program Files\\JSS\\Tomcat\\conf\\server.xml on Windows) you're going to find variables named keystoreFile and keystorePass (search for just the variables, not the whole line in Jamf's example). Change those to the path to the keystore file you copied to the DMZ JSS from the Internal JSS, and the password for it that you extracted from the server.xml file from your Internal JSS.
I made the changes to the server.xml file and followed the steps by step, but now the apache tomcat is broken. The service is not starting back. I tried to start the service, getting an error because of looking at the cert on the server.xml file.
Have you verified the access permissions on the copied keystore file are correct? Or looked at the tomcat log file to see what error(s) it shows?
Hi @sdagley so I am able to access the internal database on the external instance DMZ,  but my DMZ DNS name is different from the internal instance and I don't want to make the internal instance to the internet. when I do nslookup of my DMZ instance I can see it. not sure why not working? is that possible to use my DMZ Jamf instance different DNS name?
@NisarFawad No. The DMZ JSS must have the same public DNS name as your internal DNS name, because that's the URL the Jamf Pro agent on your Macs is configured to connect to, and it's the certificate name that the JSS will present. Each JSS will have a different IP address despite having the same DNS name, that's what's known as Split DNS
@sdagley, I'd pass out to do the clustering or internal Jamf instance connect our DMZ.
Is it possible to have one Jamf pro server with the DMZ configured with limited access? Suppose I'm trying to access the jamf pro URL outside the network route URL that is unreachable or not accessible. Only access it while connected VPN?
