Snagit 2022 Install successfully failing
  • January 28, 2022
  • 10 replies
  • 187 views
So I've followed the documentation here: https://support.techsmith.com/hc/en-us/articles/115007344888-Enterprise-Install-Guidelines-for-Snagit-on-MacOS
And I can't get this thing to install.  Specifically, i'm just trying to push Snagit out to our machines, and will follow up with the license file after I can verify the installer is actually installing the DMG/PKG.
I'm getting mixed answers between the Jamf console and the actual log file.
Jamf: "
Verifying DMG...
Verifying package integrity...
Installing Snagit.dmg...
Closing package...
In the logs all I see is.. "Instaling Snagit.dmg..."
The Dashboard indicates a successful policy push, the logs indicate a lengthy install time, longer than expected at least.
Reviewing the applications folder, it's apparent that it ISNT installed.  I've used the .DMG file directly from TechSmith, as well as trying to use Composer to create one with the same results.
Any ideas?
sdagley
  • January 28, 2022
@Rmac You cannot simply upload the Snagit 2022 .dmg download from Techsmith to your JSS and then use it as a payload package. Only Composer created .dmgs can be used that way.
You need to use Composer to create a .pkg installer from the Snagit app after you've dragged it into your Applications folder. Be sure to change the Owner/Group to Root/Admin on the app in Composer, then click the button to the right of those settings to apply owner and group to all enclosed items.
DMH2000
  • February 18, 2022
  • June 8, 2023
Hi All,
I am packaging Snagit 2023 version and we have Volume License. Once i enter the key it goes to /Users/Shared/TechSmith/Snagit/Licenses. I have embedded this Lic file in package and placed it in this location/Users/Shared/TechSmith/Snagit/Licenses on installation, however when i launch the shortcut the file is replaced and License key is removed. Anyone faced same issue or is there any other way to handle license ?
thanks
DMH2000
  • June 8, 2023
Hi All,
thanks
@Siddhi   License should go in /Users/Shared/TechSmith/Snagit. NOT a licenses folder.
See https://support.techsmith.com/hc/en-us/articles/115007344888-Enterprise-Install-Guidelines-for-Snagit-on-MacOS
  • June 9, 2023
@DMH2000 - it doesnt work if *.lic file is placed here /Users/Shared/TechSmith/Snagit. I have tried this link and not sure which option will work.
DMH2000
  • June 9, 2023
Sorry then, I've been packaging Snagit since 2020 and it's worked every time. Actually, I have a License folder, here is my setup:
├── Users
             └── Shared
                          └── TechSmith
                                         └── Snagit
                                                       ├── License
                                                       └── LicenseKey
DMH2000
  • June 9, 2023
I have been packaging Snagit since 2021 and I actually have a License folder:
├── Users
           └── Shared
                      └── TechSmith
                                 └── Snagit
                                            ├── License
                                            └── LicenseKey
topher72
  • May 15, 2025
I have a similar issue. I need to install Snagit 2025 with a LicenseKey file, however I've found it only works when added to the License folder. I need to make it and save the file in the Snagit folder, then move it to the License folder. Snagit launches and uses the License. However when using Composer to make the .pkg Snagit asks for a LicenseKey. It could be that macOS defaults the LicenseKey file to a Unix Executable File. It's a bit frustrating.
DMH2000
  • May 15, 2025
@topher72 I attached a picture, take a look at my Composer setup. Unless TechSmith changed something, it should be setup like this.  As you can see, this was the first install and we now are on 2024.  This was from our documentation i created.  Our license renews in June so won't be getting 2025 for a while.  You can always reach out to TechSmith Support with any questions.
topher72
  • May 15, 2025
@DMH2000 Thanks for that! I'm going to try that...hopefully they haven't changed the process/files in 2025
