Best way to provision major MacOS updates?
  • January 31, 2022
  • 12 views
Wondering what the best way to push out MacOS updates (specifically Monterey) would be? Through packaging the update as a policy? Thanks!
1 reply
sdagley
  • January 31, 2022
@blerud15 https://github.com/grahampugh/erase-install from @grahamrpugh is your friend for macOS upgrades. See the Wiki for instructions on using from Jamf Pro.
