Local user lookup not working in 9.65
  • March 23, 2015
  • 5 views
bpavlov
Can someone re-produce this:
Search Inventory
Search for a computer
Click on computer
Click on User and Location
Click Edit
Enter the username of a local Casper username
Click on the lookup button
Does the rest of the user fields populate with the info for the local Casper name?
We're on 9.65 and I just started noticing this. Tried it on Safari 7.1.3 and Firefox 36.0.4 so far but no luck. It worked in Casper 9.63 which is the last version we were on.
1 reply
bpavlov
  • March 24, 2015
Just to add some more notes. Looks like if I type out the first part of the local Casper username and then hit the Lookup button and then click Save. The information then populates. However, before clicking save the information does not populate.
If I instead follow the same steps above but instead enter the username of an AD account, the lookup button works as it always has and populates the user fields.
Anyone seeing this at all?
