App Inventory collection - Docker Desktop
  • February 11, 2022
  • 40 views
Hello,
I am a novice when it comes to JAMF and am wondering if there is a way I can run a report that gathers all of the installs of "Docker Desktop."  Once discovered, I would like to see if its possible to set the application to auto update
Best answer by karthikeyan_mac
You can use Advance Search for Reporting with criteria as below for reporting. Use Smart Group with the Application Title and Application Version criteria for update policy. I would recommend doing Jamf 100 to get started with Jamf. Thanks
1 reply
karthikeyan_mac
Forum|alt.badge.img+20
  • February 11, 2022
