Hey all,
Just an FYI for those out there utilizing Dockutil - the beta is out now and rewritten in Swift to be compatible with macOS 12.3 and forward. Be sure to go ahead and start testing in your environment soon. Just in case you are unaware, the older version (current 2.0.5 release) is written in the older Python which is being removed with the upcoming 12.3 update.
Link here: https://github.com/kcrawford/dockutil/releases/tag/3.0.0b
-Alex
Page 1 / 1
Thanks for the update!
