Can someone help me out creating a way to automate this manual solution process? (Full story found in Macadmins Slack)
Issue: On many computers I find that after I type
sudo profiles status -type bootstraptoken
it echo's back:
profiles: Bootstrap Token supported on server: YES
profiles: Bootstrap Token escrowed to server: YES
I proceed with typing:
diskutil apfs listCryptoUsers /
I verify that ALL users are Volume Owners. Good right? NO. Finally I type:
sudo profiles validate -type bootstraptoken
It echos back:
profiles: Bootstrap Token supported on server: NO
Manual solution: I need to go onto each computer and type
sudo profiles validate -type bootstraptoken -user INSERTUSR -pass INSERTPW
 and then identify that the echo'd line says "NO":
Once identifying is complete and found a 'NO', I type:
sudo profiles remove -type bootstraptoken -user INSERTUSR -pass INSERTPW
What echo's back is
profiles: Bootstrap Token clearing on server...
profiles: Unable to clear Bootstrap Token (500)
profiles: Error returned = 500
I checked the current status:
it echo's back:
profiles: Bootstrap Token escrowed to server: NO
I proceeded with logging out and logging back in (not a restart) and then typed:
 It Echos back:
I go a step further because I needed to in the past to TRULY validate the Bootstrap token:
 and it echos back:
profiles: Bootstrap Token escrowed on server: YES
profiles: Bootstrap Token validated.
Could create an extension attribute for the bootstrap token:
#!/usr/bin/env bash
export PATH=/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin
# Checks on if the bootstrap token is supported and escrowed by MDM
# Validating minimum OS version for attribute (10.15.0 or later)
OSVersion=$(sw_vers -productVersion)
OSVersionMajor=$(echo $OSVersion | cut -d '.' -f 1)
OSVersionMinor=$(echo $OSVersion | cut -d '.' -f 2)
if [[ $OSVersionMajor -eq 10 ]] && [[ $OSVersionMinor -lt 15 ]]; then
echo "<result>Collected for macOS 10.15.0 or later</result>"
StatusBootstrapToken=$(profiles status -type bootstraptoken 2>/dev/null)
if [[ -n $StatusBootstrapToken ]]; then
Supported='supported on server: YES'
Escrowed='escrowed to server: YES'
if [[ "$StatusBootstrapToken" == *"$Supported"* ]] && [[ "$StatusBootstrapToken" == *"$Escrowed"* ]]; then
Result="Escrowed"
elif [[ "$StatusBootstrapToken" == *"$Supported"* ]]; then
Result="Supported"
Result="Not Supported"
echo "<result>$Result</result>"
Then if it's not could just automatically install it again:
#!/usr/bin/env bash
profiles install -type bootstraptoken
