OD binding not working
  • November 25, 2011
  • 13 views
So, has anyone managed to get a newly imaged 10.7.2 client to bind to an OD server?
I can't seem to find any info on it. When I try all I get is a non-connected computer filling up the drive with a temp file containing:
Please answer (y or n):
(regarding the question to trust the certificate).
But we have a proper certificate on the server so the question should not appear, but it seems to anyways.
Any ideas?
//Patrik
sysadm Lund university
  • August 3, 2012
Are you trying to bind the computer with the OD with a script, or are you using the built in Casper OD Binding builder?
  • August 3, 2012
Clock skew?
