Not sure what I'm missing here. We have configured our Jamf ADE enrollment process and everything is working great on wired connection. However when we try and enroll via Wireless, it will install the MDM profile but fails to deploy the enrollment package/policies.
Is there something obvious we are missing? Is there a setting somewhere that needs to be enabled for wireless enrollment to work properly? The wireless Macs are still enrolled in Jamf, it's just that the enrollment package won't deploy. Looking at the logs for the enrollment package deployment, it continually lists "Could not connect to the JSS" when trying to run the enrollment policies. However after it's done, I can install apps etc from the Self Service, so it seems the issue is only during the initial enrollment process. Thanks for any help.
