Disable deskop and documents via AD accounts
  • March 24, 2022
  • 55 views
I am looking to disable editing desktop and documents on our network and so far I am not having much look.
Our Macs are linked to AD and people login with there AD accounts.
We have a suite of Macs and want to make sure people save to network drives and not the devices.
So either a script that runs on login and making it so that all accounts are setup as Guest accounts on the Macs would work I guess but not sure how to do this.
I have used scripts like the following and they all work when logged into the device but error via Jamf.
sudo -u $USER chflags uchg ~/desktop
sudo -u $USER chflags uchg ~/documents
The Errors
Script result: sudo: unknown user: chflags
sudo: error initializing audit plugin sudoers_audit sudo: unknown user: chflags sudo: error initializing audit plugin sudoers_audit
I was looking at ideally doing it via a login script as then I can exclude the admin account etc to make sure things can still be done if needed.
Best answer by dsavageED
You need to define who the logged in user is, recommended method at the moment looks like;
ACTIVE_USER=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
sudo -u $ACTIVE_USER chflags uchg /Users/$ACTIVE_USER/Desktop
dsavageED
  • March 24, 2022
  • March 25, 2022
Thank you, worked first time  😀
