how to create a bootable Catalina installer drive with latest patch?
  • April 2, 2022
  • 35 views
Folks,
Have you found that macOS Big Sur or Monterey is not such friendly for those devices carries a Intel-dual-core-CPU and 8 GB memory?
For those devices, we recommend using macOS Catalina 10.15.7. So how can we create a bootable Catalina installer drive with latest patch?
sdagley
  • April 3, 2022
@fully_wong You can't create a bootable installer with a fully patched version of Catalina 10.15.7, but you can use AutoDMG to create a disk image of a fully updated 10.15.7 install (specifically you'll need AutoDMG v1.10b587) and MacProvisioner 4.2 to create a provisioning disk which can be mounted by a Mac booted into Recovery Mode and the Mac Provisioner script run to install the AutoDMG created image.
Note: I haven't tested it since the Mac Provisioner 4.0 release, but I do not believe you can directly downgrade a Mac running Big Sur or Monterey to Catalina with this mechanism, but will have to boot from a Catalina 10.15.7 Build 19H15 installer drive to run the provisioning script.
mickgrant
  • April 3, 2022
open terminal and type
sudo softwareupdate --list-full-installers
This should list out all available full installers.
select the one you want and type
sudo softwareupdate --fetch-full-installer -full-installer-version <version number goes here>
This will download the installer to your Applications folder
To make the installer bootable, use this command
sudo /Applications/Install\\ macOS\\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/MyUSBDrive
This will then prompt you that the USB will be wiped, and then it will proceed to install the bootable installer.
sdagley
  • April 4, 2022
@mickgrant The latest available Install macOS Catalina.app is for 10.15.7 Build 19H15. If you install that you'd then need to install Security Update 2022-003 (Catalina) to update to the latest version Build 19H1824.
